brucewayne
Newbie level 3
My pic is 16f877a. Here is my code
list p=16f877a ; locates the processor file
#include <p16f877a.inc> ; defines variables inside processor
;__config _CP_OFF & _DEBUG_OFF & _LVP_OFF & _BODEN_ON & _WDT_OFF & _HS_OSC & _PWRTE_ON
__CONFIG _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _HS_OSC & _WRT_ENABLE_ON & _LVP_OFF & _DEBUG_OFF & _CPD_OFF
errorlevel 0,-302
; MEMORY LOCATIONS
Buffer EQU 0x20
DelayX EQU 0x21
DelayY EQU 0x22
DelayZ EQU 0x23
Reg1 EQU 0x24
Reg2 EQU 0x25
d_a EQU 0x26
d_b EQU 0x27
d_c EQU 0x28
; Vectors for RESET, INTERRUPT
ORG 0x0000 ;Reset Vector
GOTO Start
ORG 0x0004 ;Interrupt vector
GOTO InterruptVector
;Initial program begins here
Start
CLRF PIR1
CLRF PIR2 ;Clear interrupt flags registers
BSF STATUS, RP0 ; Set RAM Bank 1
MOVLW .7
MOVWF ADCON1 ;PortA and PortE all digital I/O
CLRF TRISB ;Port B all outputs
CLRF TRISC ;Port C all outputs
CLRF TRISD ;Port D all outputs
CLRF TRISE
CLRF TXSTA
CLRF PIE1
BCF STATUS, RP0
CLRF ADCON0
CLRF RCSTA
CLRF INTCON ;Port E all outputs
movlw H'01' ; Clock is connected to PORTB,0. Assign to Reg1,0 (current value of clock)
andwf PORTB,W
movwf Reg1
clrf Reg2
MnLoop
;Initialising LCD Display
BCF PORTE, 1 ;Set The LCD to Read only
;LED power up sequence
BCF PORTE, 0 ;Instruction register select
MOVLW .25
CALL Delay ;Delay for LCD PowerUp
MOVLW .30
CALL WrLCD ;Set LCD to 8 bits
MOVLW .5
MOVLW .30
MOVLW .5
MOVLW .30
MOVLW .5
MOVLW .56
CALL WrLCD ;8 bit interface 2 line, 5x7 character format
MOVLW .5
MOVLW .56
MOVLW .5
;Input user specific config data
MOVLW .6
CALL WrLCD ;Display shifting disabled, use cursor shifting instead
MOVLW .5
MOVLW .1
CALL WrLCD ;Clear all DDRAM and set cursor to pos 1
MOVLW .5
MOVLW .15
CALL WrLCD ;Display On & show cursor blinking with an underline
BSF PORTE, 0 ;Set to data register
UPDATE_LCD
;Input data on LCD " Student ID and Traffic Lights"
MOVLW 'S'
CALL WrLCD
MOVLW '/'
CALL WrLCD
MOVLW 'N'
CALL WrLCD
MOVLW ':'
CALL WrLCD
MOVLW '1'
CALL WrLCD
MOVLW '1'
CALL WrLCD
MOVLW '4'
CALL WrLCD
MOVLW '5'
CALL WrLCD
MOVLW '9'
CALL WrLCD
MOVLW '7'
CALL WrLCD
MOVLW '9'
CALL WrLCD
MOVLW '1'
CALL WrLCD
;Move to second line of LCD - "Traffic Lights"
BCF PORTE, 0 ;Set instruction register
MOVLW .197
CALL WrLCD
BSF PORTE, 0 ;Set data register
; Put data onto the second line - "Traffic Light Signals"
MOVLW 'G'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '6'
CALL WrLCD
BSF PORTA,0
BSF PORTA,1
BSF PORTA,2
BSF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
CALL CurrentPrevious
CALL CheckRisingEdge
BTFSS Reg2,0
CALL $-3
nop
BSF PORTE, 0
MOVLW 'G'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '5'
CALL WrLCD
BSF PORTA,0
BSF PORTA,1
BSF PORTA,2
BCF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
BTFSS Reg2,0
CALL $-3
nop
BSF PORTE, 0
MOVLW 'G'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '4'
CALL WrLCD
BSF PORTA,0
BSF PORTA,1
BCF PORTA,2
BCF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
BTFSS Reg2,0
CALL $-3
nop
BSF PORTE, 0
MOVLW 'G'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '3'
CALL WrLCD
BSF PORTA,0
BCF PORTA,1
BCF PORTA,2
BSF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
BTFSS Reg2,0
CALL $-3
nop
BSF PORTE, 0
MOVLW 'G'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '2'
CALL WrLCD
BSF PORTA,0
BCF PORTA,1
BCF PORTA,2
BCF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
BTFSS Reg2,0
CALL $-3
nop
BSF PORTE, 0
MOVLW 'G'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '1'
CALL WrLCD
BSF PORTA,0
BCF PORTA,1
BCF PORTA,2
BCF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
CALL New_Delay1
BSF PORTE, 0
MOVLW 'Y'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '0'
CALL WrLCD
BSF PORTA,0
BCF PORTA,1
BSF PORTA,2
BCF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
BTFSS Reg2,0
CALL $-3
nop
BSF PORTE, 0
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '0'
CALL WrLCD
BSF PORTA,0
BCF PORTA,1
BSF PORTA,2
BSF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
CALL New_Delay1
BSF PORTE, 0
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'G'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '6'
CALL WrLCD
BCF PORTA,0
BCF PORTA,1
BSF PORTA,2
BSF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
BTFSS Reg2,0
CALL $-3
nop
BSF PORTE, 0
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'G'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '5'
CALL WrLCD
BCF PORTA,0
BCF PORTA,1
BSF PORTA,2
BCF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
BTFSS Reg2,0
CALL $-3
nop
BSF PORTE, 0
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'G'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '4'
CALL WrLCD
BCF PORTA,0
BCF PORTA,1
BCF PORTA,2
BCF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
BTFSS Reg2,0
CALL $-3
nop
BSF PORTE, 0
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'G'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '3'
CALL WrLCD
BCF PORTA,0
BCF PORTA,1
BCF PORTA,2
BSF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
BTFSS Reg2,0
CALL $-3
nop
BSF PORTE, 0
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'G'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '2'
CALL WrLCD
BCF PORTA,0
BSF PORTA,1
BCF PORTA,2
BSF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
BTFSS Reg2,0
CALL $-3
nop
BSF PORTE, 0
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'G'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '1'
CALL WrLCD
BCF PORTA,0
BSF PORTA,1
BCF PORTA,2
BCF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
BTFSS Reg2,0
CALL $-3
nop
BSF PORTE, 0
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'Y'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '0'
CALL WrLCD
BCF PORTA,0
BSF PORTA,1
BSF PORTA,2
BCF PORTA,3
BCF PORTE, 0
MOVLW .197
CALL WrLCD
BTFSS Reg2,0
CALL $-3
nop
BSF PORTE, 0
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW 'R'
CALL WrLCD
MOVLW ' '
CALL WrLCD
MOVLW '0'
CALL WrLCD
BCF PORTA,0
BSF PORTA,1
BSF PORTA,2
BSF PORTA,3
;Write to second line of LCD
BCF PORTE, 0
MOVLW .207
CALL WrLCD
call CurrentPrevious
call CheckRisingEdge
btfsc Reg2, 0
CALL $-3
nop
BSF PORTE, 0 ; Set data register
Wait ; Infinite Loop
GOTO MnLoop ; loop to self doing nothing
;End of Main Loop
;Subroutines for writing to LCD
WrLCD ;Write to the LCD in 8 bit mode
MOVWF Buffer ;Temporarily store data to be written to the LCD
BCF PORTE, 2 ;Clear the enable pin
MOVLW .1
CALL Delay ;1ms Delay for LCD timing
MOVF Buffer, W
MOVWF PORTD ;Write stored data to PORTD ie LCD data pins
BSF PORTE, 2 ;Pulse Enable pin
NOP
BCF PORTE, 2
RETURN
CurrentPrevious
movf Reg1, F ; move the previous reading to reg1,1 and put the new one in Reg1,0
movlw H'01' ; Assign clock to Reg1,0
andwf PORTB,W
iorwf Reg1,F
movlw H'03'
andwf Reg1,f
return
CheckRisingEdge
btfsc Reg1,1
goto NoRisingEdge
btfss Reg1,0
goto NoRisingEdge
bsf Reg2,0 ; Rising edge
return
NoRisingEdge
bcf Reg2,0 ; No rising edge
return
New_Delay1 ;Delay for 2s, count cycles based on 20Mhz clock
MOVLW 0x5A
MOVWF d_a
MOVLW 0xCD
MOVWF d_b
MOVLW 0x16
MOVWF d_c
New_Delay2 ;Delay for some ms, count cycles based on 20Mhz clock
DECFSZ d_a, f
GOTO $+2
DECFSZ d_b, f
GOTO $+2
DECFSZ d_c, f
GOTO New_Delay2
; One complete cycle
NOP
Delay ;Delay for some ms, count cycles based on 20Mhz clock
MOVWF DelayX
OutLoop
MOVLW .29
MOVWF DelayY
MidLoop
MOVLW .42
MOVWF DelayZ
InLoop
NOP
DECFSZ DelayZ, F
GOTO InLoop
DECFSZ DelayY, F
GOTO MidLoop
DECFSZ DelayX, F
GOTO OutLoop
RETURN
; Interrupt Service Routine
InterruptVector ; Empty the vector in case
RETFIE ; finish interrupt and return
END
