bolongsox
Newbie level 1
ericsson t28sc
I'm doing an interfacing project between atmega32 and ericsson t28 mobile phone, everything works right, the mcu can connect to mobile phone and talk to each other nicely, but when i tried to send prepackaged PDU ( i don't need any on the fly encoded PDU since all i need is to send predefined message to predefined mobile number ), the AT+CMGS=xx command got ERROR response.
Using Hyperterminal also result in the same ERROR, while issuing test command seems to indicate that SMS related AT command set are all supported ( +CMGF, +CMGS, +CMGL, etc. )
Is there any specific initialization sequence to perform beforehand ?
Just for information, I use direct connection between mcu and mobile phone, with voltage limiting zener diode in mcu tx line ( t28 works at 3.6v, while my mcu board is 5v ). I'm pretty sure that this is not hardware problem though, my suspicion is incorrect initialization... any advise will be greatly appreciated
