equivalent resistance solution help
tolifull
Find the equivalent resistance from a point A to B can anybody please help me thank you ....
do you think you can solve this problem sir... thank you
first calculate the two resistors on the right which are in series, then use that result in parallel with the middle resistor and finally use the last result is series with the two resistors in the left.
Alex
Do you know how to to calculate the parallel and series connected resistance?. here is how to do see text in the image:
I don't see how solving his homework will help him learn.
Alex
hi ALEX
Hi Alex thank you for help but I still dont understand until I see it, so if you can solve whole this DIAGRAM so please you have time can you send me an e - mail of whole of your work on mentor-sh@hotmail.com ... once again thank you
To find the the total resistance of two resistors connected in series you add them, Rtotal=R1+R2.
When they are connected in parallel then Rtotal = (R1*R2)/(R1+R2)
use this
first calculate Rtotal1
then use Rtotal1 to calculate Rtotal2 with the resistors in parallel
and finally use Rtotal2 in series with the remaining resistors to calculate Rtotal
Alex
I think he is not interested in learning. He just wants to finish the assignment. He did not make any question on the replies but insisted to send him main for the solved example.
I have send him a private message its not that I dont want to learn, but however thank you for writing too
and I am sorry if you meant that I don't want to study...
and if you can tell me what law we have to load in the example, I think I have to use the Ohm's law if I am right for this example ?
The equation that is used for series resistors is explained
and for parallel resistors at
They are based on Ohm's law
Alex
Alex sorry for late replay, once again thank you and I will try to find the solution when I get home after my work time... and I will see what can I do you have a great time and thank you once again
You are welcome.
If you just want to solve the circuit then the simplified equations of post #8 are enough, in the links of post #11 is the explanation of how we have come up with these equations which is useful to know but will not be used to solve your circuit.
Alex
