To avoid equalizing, you may use a differential modulation method for each channel, like DPSK. This is simpler, however the performance may not be enough for your application.
Hi
After sending pilot, you can easily calculate the coefficients of the channel. After that you can just divide the received symbol by channel coefficients.
