Enquiry of UHF tag antenna design
guillaumechen
Junior Member level 1
Hi all,
I'm now designing a UHF tag antenna with inductively coupling. For UHF band, the operating range of frequency is from 908MHz ~ 914MHz. However, from my simulation result of return loss - frequency, I found out that the minium point of return loss was left shifted (around 820MHz). How can I improve my design so that the whole curve of return loss can be re-located inside the UHF band?
Please help me~Thanks a lot.
Best Regards,
Guillaume
Hi FvM,
Thanks for your suggestion. I had made an improvement after adjusting the dimension of patch. However, the diagram of return loss had an undesirable peak at the RHS of the frequency. What should I do to eliminate this peak?
Best Regards,
Guillaume
I wonder how you get a positive dB return loss. Is your antenna generating energy?
I'm not familiar to HFSS, but something seems to be wrong in your simulation setup.
The setting of my tag antenna:
-Substrate:
40(X) x 50(Y) x 1.6(Z) mm; FR4_epoxy
(The antenna is located at the middle of the vacuum box)
-Vacuum Box:
80(X) x 80(Y) x 50(Z) mm; vacuum
-LumpPort:
16 + j380 {because my chip impedance is 16 - j380 (chip cannot be changed!)}
(Any others please check the attachments~)
Please HELP~~
