neoflash
Advanced Member level 1
In a high-speed system with multi-gigabit serial interface, the link data rate and the transmission distance are often limited by channel loss. Serial signal redriver can extend the distance of the link. Sitting between the transmitter and receiver, the redriver not only restores the attenuated signal amplitude, but also reduces ISI timing jitter.
This is the first chapter I prepared for a document. But I have so much confusion of using "the". Can any native speaker help me with it?
Added after 16 minutes:
I tried to make another version. But not sure which one has less mistakes.
In a high-speed system with multi-gigabit serial interface, link data rate and transmission distance are often limited by channel loss. Serial signal redriver can extend the bandwidth of a link. Sitting between a pair of transmitter and receiver, a redriver not only restores attenuated signal amplitude, but also reduces ISI timing jitter.
