farhadhg
Newbie level 1
I am having a problem with ELC to characterize a cell in TSMC65nm technology and I would appreciate if anyone could help me. The problem is with db_spice command which gives me the following error and it also does not create any log, i.e. encounter.log and encounter.work folders are empty at the end. So, I cannot track the problem!
The error is:
[WARNING(db_spice)]No spice simulation to do, please check the cell/process list for any error.
The scripts I use are:
Script1 )step1:
db_open foo
set_var EC_SPICE_SIMPLIFY true
set_var EC_HALF_WIDTH_HOLD_FLAG true
set_var EC_SIM_NAME "spectre"
set_var EC_SIM_TYPE "spectre"
set_var EC_SPICE_SUPPLY1_NAMES "VDD"
set_var EC_SPICE_SUPPLY0_NAMES "VSS"
db_prepare -f
db_gate
db_close
exit
Script 2)step2:
db_open foo
set_var EC_SIM_USE_LSF 1
set_var EC_SIM_LSF_CMD ""
set_var EC_SIM_LSF_PARALLEL 10
db_spice -s spectre -p typical -keep_log
db_close
exit
elccfg:
# Setup stuff
SETUP = "setup.st"
PROCESS = "typical"
SUBCKT = "tcbn65gplus_200a_lpe.spi"
MODEL = "crn65gplus_2d5_lk_v1d0.scs"
Thanks,
Farhad
The error is:
Script1 )step1:
db_open foo
db_prepare -f
db_gate
db_close
exit
Script 2)step2:
db_open foo
db_close
exit
elccfg:
# Setup stuff
SETUP = "setup.st"
PROCESS = "typical"
Thanks,
Farhad
