hans_r
Newbie level 5
- Joined
- Apr 12, 2012
- Messages
- 10
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,362
I'm doing a design using a clock mesh, and I would like to do spice extraction for back annotation in Encounter. In my clock mesh spec file I have the library defined like this:
Analysis
MultiPartSpice true
MultiPartSpicePartitionLevel 4
End
SpiceLib
Library toplevel.l TOP_TT
Include drive_cells.sp
Global Power VDD
Global Ground VSS
SubcktPortSeq drive_cells.spo
End
When I try to specify the clock mesh using the clock mesh file, I get the following error:
**ERROR: (ENCCM-192): Failed parsing clock mesh specification at or near NTmesh.spec:64. Reason: Unexpected token "SpiceLib".
Any help?
When I comment out the full analysis and spicelib section, I can load the clock mesh spec file without any problems....
Kind regards!
Analysis
MultiPartSpice true
End
SpiceLib
Global Power VDD
Global Ground VSS
End
Any help?
Kind regards!
