roy_ece
Member level 3
When I try to run encounter session for MOSIS 0.5um process. Encounter tool is abnormally getting terminated.
**WARN: (SOCFP-3362): No core row in the design.
Encounter terminated by internal (SEGV) error/signal...
*** Stack trace:
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter(syStackTrace+0x146)[0xd0ce44f]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter[0x8cf5ae8]
[0xffffe600]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter(_Z14winTextExtentsP7winsWinP9winsLayerPcPiS4_S4_+0x75)[0xcf5264d]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter(_Z16winDrawTextInBoxP7winsWinP9winsLayerPcP6sysBoxici+0x23b)[0xcf8e951]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter[0xcf6d817]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter[0xcf6d921]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter[0xcf6dbbe]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter(_Z20winViewListIterationP7winsWini+0xf4)[0xcf55f5a]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter(_Z13winDbDrawViewP7winsWin+0x257)[0xcf7ccf1]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter(_Z10winDisplayP7winsWin+0x9a)[0xcf503f0]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter[0xcf53738]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter(TclServiceIdle+0x59)[0xdee9469]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter(Tcl_DoOneEvent+0x16e)[0xded9dfe]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter(Tcl_AppInit+0x453)[0x8cda7ef]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter(Tk_MainEx+0x25e)[0xddfc91e]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter(_Z7fe_mainiPPc+0x43e)[0x8cdac3a]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter(main+0x79)[0x8cdaf1d]
/lib/libc.so.6(__libc_start_main+0xdc)[0x83fe9c]
/usr/local/Cadence/SOC71/tools/fe/bin/32bit/encounter[0x8cda2b1]
pstack
Thread 4 (Thread 0xf6c5eb90 (LWP 24192)):
#0 0xffffe410 in __kernel_vsyscall ()
#1 0x009922f6 in nanosleep () from /lib/libpthread.so.0
#2 0x09ef7db0 in rdaiLicRecheck(void*) ()
#3 0x0098a832 in start_thread () from /lib/libpthread.so.0
#4 0x008fbf6e in clone () from /lib/libc.so.6
Thread 3 (Thread 0xf625db90 (LWP 24193)):
#1 0x008f4b31 in select () from /lib/libc.so.6
#2 0x0defc5dc in NotifierThreadProc ()
Thread 2 (Thread 0xf585cb90 (LWP 24194)):
#1 0x00992c4e in do_sigwait () from /lib/libpthread.so.0
#2 0x00992cef in sigwait () from /lib/libpthread.so.0
#3 0x08cf5e91 in ctrlCHandle(void*) ()
#4 0x0098a832 in start_thread () from /lib/libpthread.so.0
#5 0x008fbf6e in clone () from /lib/libc.so.6
Thread 1 (Thread 0xf7ac76c0 (LWP 24142)):
#1 0x008bb73b in waitpid () from /lib/libc.so.6
#2 0x0086007b in do_system () from /lib/libc.so.6
#3 0x00860412 in system () from /lib/libc.so.6
#4 0x00992ead in system () from /lib/libpthread.so.0
#5 0x0d0ce4b6 in syStackTrace ()
#6 0x08cf5ae8 in rdaiErrorHandler(int, siginfo*, void*) ()
#7 <signal handler called>
#8 0x00b735ce in XTextExtents () from /usr/lib/libX11.so.6
#9 0x0cf5264d in winTextExtents(winsWin*, winsLayer*, char*, int*, int*, int*) ()
#10 0x0cf8e951 in winDrawTextInBox(winsWin*, winsLayer*, char*, sysBox*, int, char, int) ()
#11 0x0cf6d817 in winiDrawFTerm(winsWin*, dbsFTerm*, winsLayer*, winsLayer*) ()
#12 0x0cf6d921 in winiFTermDraw(winsWin*, dbsObject*) ()
#13 0x0cf6dbbe in winiFTermIter(winsWin*, void (*)(winsWin*, dbsObject*)) ()
#14 0x0cf55f5a in winViewListIteration(winsWin*, int) ()
#15 0x0cf7ccf1 in winDbDrawView(winsWin*) ()
#16 0x0cf503f0 in winDisplay(winsWin*) ()
#17 0x0cf53738 in winiTkDisplay(void*) ()
#18 0x0dee9469 in TclServiceIdle ()
#19 0x0ded9dfe in Tcl_DoOneEvent ()
#20 0x08cda7ef in Tcl_AppInit ()
#21 0x0ddfc91e in Tk_MainEx ()
#22 0x08cdac3a in fe_main(int, char**) ()
#23 0x08cdaf1d in main ()
gdb
Using: gdb
[Thread debugging using libthread_db enabled]
[New Thread 0xf585cb90 (LWP 24194)]
[New Thread 0xf625db90 (LWP 24193)]
[New Thread 0xf6c5eb90 (LWP 24192)]
A debugging session is active.
Inferior 1 [process 24142] will be detached.
Quit anyway? (y or n) [answered Y; input not from terminal]
*** Stack trace:
[0xffffe600]
pstack
gdb
Using: gdb
