Hello,
I have been trying to enable code coverage in VCS and running into some issues.
I added "-cm line" switch to my compile and simulation and
" -metric line" to the command used to extract the line coverage information from the vdb.
The command I use is,
urg -metric line -dir <path_dir> -dbname <path_to_vdb>
The problem is, I only see coverage getting enabled at the leaf nodes. I also have verilog code sometimes at the parent level.
For e.g.
root
|_parent
|_leaf
I can only see the line coverage enabled at leaf whereas I want it at parent too.
Is there a depth switch missing in my build?
Any response is appreciated.
