[SOLVED] enable interrupt in pic18 in c18 compliler
shreyas_patel21
Full Member level 3
Full Member level 3
hello everyone,
how to enable external interrupt or IOC(interrupt on change) in pic18f46k22?
i am using microchip mplab c18 compiler.
here is the code which i tried:
#include <stdio.h>
#include <p18f46k22.h>
#define LED PORTDbits.RD2
#define push_butten PORTDbits.RD5
void ioc(void);
#pragma code low_vector=0x18
void low_interrupt (void)
	_asm GOTO ioc _endasm
#pragma code
#pragma interruptlow ioc
void ioc(void)
	LED=push_butten;
void delay(int ms)
	unsigned int x;
	T1CON=0x00;
	for(x=0;x<ms;x++)
		TMR1L=0x00;
		T1CON=0x33;
		while(TMR1L<0xFA);
		T1CON = 0x0000;
void main()
	OSCCONbits.IRCF0 =1;
	OSCCONbits.IRCF1 = 1;
	OSCCONbits.IRCF2 = 1;
	OSCTUNEbits.PLLEN = 1;
    ANSELA = 0x00;
    ANSELB = 0x00;
    ANSELC = 0x00;
    ANSELD = 0x00;
    ANSELE = 0x00;
	TRISA=0x00;
	TRISB=0X0000;	//output
    TRISC=0X0000;	//output
    TRISD=0X00;	//output
    TRISE=0X00;	//output
	LED=1;
	IOCB=0xff;
	INTCONbits.RBIE=1;
	while(1)
		push_butten=1;
		delay(2500);
		push_butten=0;
		delay(2500);
thank you.
You should enable GIE and teh correspondent INTxIE register. For INT0IE both are on INTCON. DOnt forget to clear the flag!!
Cya
thanks Sink0,
I had already enabled that interrupt in
INTCONbits.RBIE=1;
line
i also checked by clearing the flag.
my updated code is:
#include <stdio.h>
void delay(int ms)
	unsigned int x;
	T1CON=0x00;
	for(x=0;x<ms;x++)
		TMR1L=0x00;
		T1CON=0x33;
		while(TMR1L<0xFA);
		T1CON = 0x0000;
void main()
    ANSELA = 0x00;
    ANSELB = 0x00;
    ANSELC = 0x00;
    ANSELD = 0x00;
    ANSELE = 0x00;
	TRISA=0x00;
	TRISB=0Xffff;	//output
    TRISBbits.RB7=1;
    TRISBbits.RB6=1;
	LED=1;
	WPUB=0xff;
	IOCB=0xff;
	PORTB=0x0000;
	INTCONbits.RBIF=0;
	INTCONbits.RBIE=1;
	INTCONbits.RBIF=0;
	INTCON2bits.RBIP=0;
	INTCON2bits.RBPU=0;
	push_butten=1;
	while(1)
		if(INTCONbits.RBIF==1)
			LED=~LED;
			INTCONbits.RBIF=0;
//		push_butten=1;
		delay(250);
//		push_butten=0;
		delay(250);
now i am getting interrupt but when interrupt pin gets logic high it always go in interrupt state.
and when logic 0 it never go to interrupt.
thank you
---------- Post added at 17:56 ---------- Previous post was at 17:07 ----------
i got the solution!
i forgot to end the mismatch by reading the port B before clearing the interrupt flag.
here is the working code.
#include <stdio.h>
void delay(int ms)
	unsigned int x;
	T1CON=0x00;
	for(x=0;x<ms;x++)
		TMR1L=0x00;
		T1CON=0x33;
		while(TMR1L<0xFA);
		T1CON = 0x0000;
void main()
	unsigned int mismatch;
    ANSELA = 0x00;
    ANSELB = 0x00;
    ANSELC = 0x00;
    ANSELD = 0x00;
    ANSELE = 0x00;
	TRISA=0x00;
    TRISBbits.RB7=1;
	LED=1;
	WPUB=0xff;
	IOCB=0xff;
	PORTB=0x0000;
	INTCONbits.RBIF=0;
	INTCONbits.RBIE=1;
	INTCONbits.RBIF=0;
	INTCON2bits.RBIP=0;
	INTCON2bits.RBPU=0;
	push_butten=1;
	while(1)
			LED=~LED;
			mismatch=PORTB;
			INTCONbits.RBIF=0;
		push_butten=1;
		delay(250);
		push_butten=0;
		delay(250);
i have connected push_butten pin to the interrupt pin.
thank you.
