EMI/EMC weighing M/c Tested for Susceptibility failed
kumar
Member level 4
Member level 4
Hi!
I got a electronics weighing M/c Tested for Susceptibility test. It failed between 350 - 450 MHz. The test range was 80 to 1000 MHz. Could someone help me with the reasons for this happening.
Thanks
Bye!
Hi.
There are many reason for failing in EMC tests.
Can be more specific, please? What appen to your unit?
Some points to :
- What about your analog inputs? If you are using OP-Amp are the inputs correctly filtered?
- What about your PCB? Are you using a correctly routed PCB? (From EMC point of view). Is your ground path right?
- What about your casing? (Is a good shield?)
- What about cables connected to your unit? (are they filtered?)
This can be only a starting point... but anyway..
GOOD LUCK !!
Since you failed susceptibility is such a specific band, I would look for resonant structures.
Look for an opening in the shield/case that could be acting as a waveguide for the band you failed. Cable entryways are frequent sources.
Look for circuit areas (long traces, wires, etc) that could be resonant antenna structures - a Grid Dip Meter can be helpful in this endeavor.
Without more specific information, the above is all I can immediately think of.
Re: EMI/EMC
check your filter circuit clearly once again.
