zainka
Full Member level 2
Hi
I would like to have tip on manufacturers of small camera sensors and/or modules and lens manufacturers. Also colore filters for given wave lengths is in interest
I am in the need of a small camrea capable of taking images in a rate of up to 20 fps with a wide angle lens of minimum 110* . Resolution is not critical, low res. is ok. Camera should be able to be interfaced serial and one should be able to read raw data, line by line.. No colore is prefferable.
Application is a device that will in a controlled environment take an image, and search for a pattern.
Device will not store the images, just load , check, and forget.
Thanks in advance
Vidar (Z)
Thanks in advance
Vidar (Z)
