yentran
Newbie level 1
I have a class project which is "16 stories elevator controller ". I have a problem with the counter issued. For example, I set switch to get to a desired floor is 6, and the counter count-up from 1 2 3 4 5 6 and count down to 5. Here is my following code.
module top_module(
input [3:0] iSw,
input iGo,
input clk,
input iRst,
output [3:0] cFloor
wire [3:0] odFloor;
wire up_down;
wire oeq;
wire orun;
wire ogo;
comp4 inst1 ( .iP(odFloor), .iQ(cFloor), .oPgtQ(up_down), .oPeqQ(oeq));
floor_cnt inst2 ( .clk(clk), .rst(iRst), .en(orun), .act(up_down), .cFloor(cFloor));
fsm inst3 (.clk(clk), .go(ogo), .eq(oeq), .rst(iRst), .done(), .run(orun), .open());
L2P inst4 ( .clk(clk), .rst(iRst), .L(iGo), .P(ogo));
vreg inst5 (.iSw(iSw), .rst(iRst), .clk(clk), .mode(ogo), .dFloor(odFloor));
endmodule
module comp4(
input [3:0] iP,
input [3:0] iQ,
output oPgtQ,
output oPeqQ
// Add internal wires
wire [3:1] PgtQ, PeqQ;
// Instantiate to comp1 to create 4-bit iterative comparator
comp1 comp1_3_i (.iP(iP[3]), .iQ(iQ[3]), .iPgtQ(1'b0), .iPeqQ(1'b1), .oPgtQ(PgtQ[3]), .oPeqQ(PeqQ[3]));
comp1 comp1_2_i (.iP(iP[2]), .iQ(iQ[2]),.iPgtQ(PgtQ[3]), .iPeqQ(PeqQ[3]), .oPgtQ(PgtQ[2]), .oPeqQ(PeqQ[2]));
comp1 comp1_1_i (.iP(iP[1]), .iQ(iQ[1]),.iPgtQ(PgtQ[2]), .iPeqQ(PeqQ[2]), .oPgtQ(PgtQ[1]), .oPeqQ(PeqQ[1]));
comp1 comp1_0_i (.iP(iP[0]), .iQ(iQ[0]),.iPgtQ(PgtQ[1]), .iPeqQ(PeqQ[1]), .oPgtQ(oPgtQ), .oPeqQ(oPeqQ));
endmodule
module comp1(
input iP,
input iQ,
input iPgtQ,
input iPeqQ,
output oPgtQ,
output oPeqQ
assign oPgtQ = iPgtQ | iPeqQ & (iP & ~ iQ) ;
assign oPeqQ = ~iPgtQ & iPeqQ & (~iP ^ iQ);
endmodule
/* This is a floor counter machine. When the signal 'act' in high,the counter will count up and vice versa */
module floor_cnt(
input clk,
input rst,
input en,
input act,
output reg [3:0] cFloor
always@(posedge clk, posedge rst)
if (rst)
cFloor <= 0;
else if (en)
if (act)
begin
cFloor <= cFloor +1;
end
else
begin
cFloor <= cFloor -1;
end
endmodule
/*This is a state machine for the elevator */
module fsm(
input clk,
input go,
input eq,
input rst,
input done,
output run,
output open
parameter S_W4go = 2'b00; // state at the door close and wait for input
parameter S_run = 2'b01; // state at the door close and the elevator runs after input is asserted
parameter S_open = 2'b10; // state at the door is open when input is at the right floor
reg [2:0] state, next_state;
// Sequential logic
always @(posedge clk, posedge rst)
if (rst)
state <= S_W4go;
else
state <= next_state;
// Next state logic
always @(*)
if (rst) next_state <= S_W4go;
else case (state)
S_W4go: if (go) next_state <= S_run;
else next_state <= S_W4go;
S_run: if (eq) next_state <= S_open;
else next_state <= S_run;
S_open: if (done) next_state <= S_W4go;
else next_state <= S_open;
default: next_state <= S_W4go;
endcase
// Output logic
assign run = (state==S_run);
assign open = (state==S_open);
endmodule
/* This is level to pulse module which is the input high for 3 consecutive clock will
generate an output high*/
module L2P(
input clk,
input rst,
input L,
output P);
// parameter [2:0] S0=000, S1=001, S2=010, S3=011, S4=100;
parameter [2:0] S0=0, S1=1, S2=2, S3=3, S4=4;
// Define the next state combinational circuit
always@(L,state)
case(state)
S0: if(L)
next_state = S1;
else
next_state = S0;
S1: if(L)
next_state = S2;
else
next_state = S0;
S2: if(L)
next_state = S3;
else
next_state = S0;
S3: if(L)
next_state = S4;
else
next_state = S0;
S4: if(L)
next_state = S4;
else
next_state = S0;
default: next_state= 3'bxxx;
endcase
// Define the sequential block
always@ (posedge rst, posedge clk)
if(rst)
state <= S0;
else
// Define output
assign P =(state==S3);
endmodule
/* this is a 4-bit register paralle loading. If mode is high,the data is loaded by iSw */
module vreg(
input [3:0] iSw,
input rst,
input clk,
input mode,
output reg [3:0] dFloor
if (rst)
dFloor <= 0;
else
if (mode)
begin
dFloor <= iSw;
end
endmodule
/* this is a test fixture */
module top_module_tf;
// Inputs
reg [3:0] iSw;
reg iGo;
reg clk;
reg iRst;
// Outputs
wire [3:0] cFloor;
// Instantiate the Unit Under Test (UUT)
top_module uut (
.iSw(iSw),
.iGo(iGo),
.clk(clk),
.iRst(iRst),
.cFloor(cFloor)
always
#10 clk = ~clk;
initial begin
// Initialize Inputs
iSw = 0; iGo = 0; clk = 0; iRst = 1;
#10 iSw =4'd6; iGo=1; iRst =0; clk =1;
#90 iGo =0;
// Wait 100 ns for global reset to finish
#200 $finish;
end
endmodule
// Thanks in advance everybody !!!
module top_module(
input [3:0] iSw,
input iGo,
input clk,
input iRst,
output [3:0] cFloor
wire [3:0] odFloor;
wire up_down;
wire oeq;
wire orun;
wire ogo;
endmodule
module comp4(
input [3:0] iP,
input [3:0] iQ,
output oPgtQ,
output oPeqQ
endmodule
module comp1(
input iP,
input iQ,
input iPgtQ,
input iPeqQ,
output oPgtQ,
output oPeqQ
endmodule
module floor_cnt(
input clk,
input rst,
input en,
input act,
if (rst)
cFloor <= 0;
else if (en)
if (act)
begin
end
else
begin
end
endmodule
module fsm(
input clk,
input go,
input eq,
input rst,
input done,
output run,
output open
// Sequential logic
if (rst)
state <= S_W4go;
else
// Next state logic
always @(*)
else case (state)
endcase
// Output logic
endmodule
module L2P(
input clk,
input rst,
input L,
output P);
always@(L,state)
case(state)
S0: if(L)
next_state = S1;
else
next_state = S0;
S1: if(L)
next_state = S2;
else
next_state = S0;
S2: if(L)
next_state = S3;
else
next_state = S0;
S3: if(L)
next_state = S4;
else
next_state = S0;
S4: if(L)
next_state = S4;
else
next_state = S0;
endcase
if(rst)
state <= S0;
else
// Define output
endmodule
module vreg(
input [3:0] iSw,
input rst,
input clk,
input mode,
if (rst)
dFloor <= 0;
else
if (mode)
begin
dFloor <= iSw;
end
endmodule
// Inputs
reg [3:0] iSw;
reg iGo;
reg clk;
reg iRst;
// Outputs
wire [3:0] cFloor;
top_module uut (
.iSw(iSw),
.iGo(iGo),
.clk(clk),
.iRst(iRst),
.cFloor(cFloor)
always
#10 clk = ~clk;
initial begin
#90 iGo =0;
#200 $finish;
end
endmodule
