neazoi
Advanced Member level 6
- Joined
- Jan 5, 2008
- Messages
- 4,157
- Helped
- 13
- Reputation
- 26
- Reaction score
- 15
- Trophy points
- 1,318
- Location
- Greece
- Activity points
- 37,198
Hello,
I would like to make a very sensitive voltage detector, to measure the voltage out of the detector of a crystal set or generally detector diodes without loading them much.
I have found this simple circuit
Which can measure also both polarities.
1. Would this be suitable (any better solution)?
2. Does R2 control the meter zero position?
3. Can I increase the 1M resistor to 10M to reduce sensitivity (and load the circuit under measurement less)?
4. Can I connect a set of antiparallel 1n4148 (or other?)at the fet gate, to protect the fet from overvoltage?
Also what about this circuit https://www.circuitstoday.com/wp-co...ier-Transistorized-DC-Voltmeter-using-FET.jpg from that page https://www.circuitstoday.com/dc-voltmeters will it be any better or not?
