Hi everyone,
I'm having some doubts in understanding of electromagnetic waves & Field.
As my understand,
Electromagnetic Field- Principle of Changing Magnetic Field which changes Electric Field (i.e, Hall Effect Sensor)
Electromagnetic Waves- Principle of Changing Electric Field which changes Magnetic Field (i.e, Wireless broadcasting systems)
Pls Clarify,
1. Passing Current through a Iron Particle Produces Electromagnetic Field , which magnetic field can be altered only by some magnetic particle.
why the magnetic field was not able to change with non-magnetic iron particle?
2. Coil Wounded over the Rectangular bobbin, Permanent magnet is kept to the rectangular bobbin, which magnetic field can be alter by simple iron particle.
what is concept of the magnetic field here?
Both of above concepts are used in speed measurement.
3. Current passing through coil, which stores energy in the form of magnetic field, usually used in broadcasting system,
what is the name of field, howlong the energy is withstanding?
