RhinoCan
Newbie level 6
This is a very basic question about GFI (Ground Fault Interrupt?) outlets. I do NOT know much about electronics and had only brief courses in electricity in high school, which was a long time ago.
My mother has a standard-looking GFI outlet in her kitchen and it stopped working a while back. She mentioned it this past weekend when I was there so I took a look to the best of my very limited abilities. Basically, I checked to make sure that the breaker for that outlet hadn't been tripped - it hadn't - and that there each of the wires going to the outlet were securely attached - they were. (I don't know if the wires were attached to the RIGHT terminals, all I know is that none had come detached.)
Is there anything further I can do short of calling an electrician? I was thinking that I could simply replace the GFI outlet with another one and see if that sorted things out. I have no idea how reliable those outlets are and if a total failure of the outlet after several years would be totally routine or very unlikely.
Are there any other plausible explanations for why the outlet no longer works, especially simple things that I might attempt to fix myself with my very basic knowledge?
