efficient parallel real time upsampling
lgeorge123
Full Member level 2
Full Member level 2
Hong Kong
Under this article using xilinx FPGA , a process is only to implement a upsample factor of 4 ,a 16 FIR filter coefficients are used, so what if a upsamle factor is 10 , is it need to use 100 fir filter coefficients ?
  • efficient-parallel-real-time-upsampling-with-xilinx-fpgas.pdf
No. FIR filter coefficients count is independent of sampling rate. It depends on filter characteristic.
But if you change sampling rate you need to adjust filter coefficients (value) to get the same filter characteristic.
Klaus
So please give me some advice , if the up sampling factor is 10 , what is the number of fir filtering coefficients?
