ECG problem- osciloscope laboratory result is too noisy
acilaw
Newbie level 2
ECG problem
Please, I need your advice in this schematic.
I test with my osciloscope laboratory but the result is so noisy, I wonder is there any wrong with my schematic..
I'm sorry my bad english..:|
thk and regard.
Re: ECG problem
This is a high gain circuit. I believe the TL071 is too noisy to serve as an amplifier for these signals (seems that IC3 is used as a guard-ring buffer). Also, carefully decouple the power supply near all op-amps and take care of your lay-out.
Regards
Re: ECG problem
Regards
I have replace the IC3 with OP97, but waveform result still same :( ,maybe I should change supply with separated battery.
