"ECAN" pin's of dsPIC33EP256MU810 (or) dsPIC24EP256GU810
wp100
Advanced Member level 6
Prime Meridian
Think thats is because its down to you what pins the Can modules uses.
See the datasheet PPS section register RPINR26 on page 224.
bigdogguru
Administrator
Advanced Member level 7
Southwest, USA
As wp100 indicated many of the peripheral module I/O must be mapped to a specific physical pin of the device.
This approach allows the device to offer many different peripheral modules, while conserving the number of require port pins to only those peripheral modules utilized.
The required techniques of mapping are covered in the following reference:
Section 30. I/O Ports with Peripheral Pin Select (PPS)
The dsPIC33 series also shares many of the features offered by the PIC24H series:
Engscope Tutorial - 05 Inputs and Outputs
BigDog
