EbNO for MIMO systems
white4
Newbie level 6
Good evening.
I am simulating a MIMO channel, but I have a doubt about adding noise. I am measuring the BER vs EbNo, but Matlab function AWGN requests SNR. I already know that SNR = EbNo + 10log(spectral efficiency), but I don't know what spectral efficiency is while transmiting 4x4 mode with QPSK modulation in each channel. The whole system efficiency is 8bits/s/Hz, but while transmiting, they are "independent" channels whose efficiency is 2bits/s/Hz.
What spectral efficiency should I use?
Thank you.
similar question.
I suppose by using QPSK, a 2bit signal is converted into one QPSK symbol.
does that mean the spectral efficiency?
