Easily variable active low-pass filter?
PgrAm
Newbie level 6
Newbie level 6
I've been trying to design an active low pass filter that can have both the cutoff frequency and gain adjusted independently using single potentiometers. This is what I have come up with:
Unfortunately there are several problems my design:
  • its essentially a passive filter which is then amplified
  • its non-inverting
Anyone know of an inverting circuit which can have gain and frequency easily adjusted by one potentiometer each?
Hmm that's an interesting idea although trasconductance op-amps don't seem to be as readily available as regular ones. Surely there must be a circuit that uses standard op-amps.
What about the classical first order active lowpass filter?
Circuit: R2||C2 in the feedback path (between output and inverting input); R1 between signal input and inv. opamp input node.
Gain: -R2/R1 with R1>>potentiometer
3-dB cutoff: 1/(R2C2) with R2>>potentiometer.
The problem with that circuit is that adjusting the value of R2 to modify the frequency will also alter the gain.
All first order filters are functionally equivalent (they have a real pole), so what should be the advantage of using a different topology than that shown in post #1?
In the last line of post#1 the OP did ask for an inverting topology.
This circuit may be suitable.
- It's inverting.
- Input impedance is constant and resistive.
- Gain can be adjusted above or below unity.
It's still only first order, but could easily be adapted to second order. The OP didn't mention what order (s)he wants.
Transconductance OpAmp are available in Farnell or RS components, you can get plenty of them. One interesting feature is that their bandwidth is much higher compared to the ordinary voltage feedback OpAmp. You can create easily adjustable low pass or high pass filters with them. If you need narrow band pass filter you need to use combination of low pass and high pass filter.
But I agree - they are not widely used and you need to learn how to work with them.
Kind regards,
Luben
