Eagle PCB short circuit check
jabidof
Member level 5
eagle circuit
Does anyone know if there is a way to check in Cadsoft Eagle PCB software at board level if there is a short circuit between 2 signals?
pcb short circuits
search the board and you will find lot of posts and help regarding the EAGLE
eagle pcb
sau_sol:
Sounds like you have an idea where those information could be found.
Can you be so kind and let us know in here?
circuit check
Hello!
You have to use the "DRC" (DRC stands for Design Rules Check).
It's one of the last buttons of the left buttons column. If you leave the mouse
on it, it should popup a small label "DRC".
When you check the rules, a short circuit will be referred to as "overlap"
in the check results.
Dora
jabidof said:
    jabidof
checking for short circuit
Thanks!
locatıon of pcb shorts
you can also check this post for further information
