DxDesigner - Allegro flow
majnoon
Full Member level 5
dxdesigner netlist to allegro
Yes it is.
Even though Allegro native schematic is HDL and not long ago OrCAD Capture was also added.
STill you can upload netlist from other tools into Allegro. In your case generate netlist in Viewlogic then in Allegro import Logic and use Other.
You can edit .cfg file to bring properties from DxDesigner into Allegro.
Regards,
M
    popoyboys
majnoon
Full Member level 5
import a dxdesigner netlist into allegro
It worked on 15.7 and older DXD so no reason it should not work on 16.
What related doc you need?. As I said creat netlist and import netlist.
M
