.dwg to gerber format ?
sumit007
Member level 3
dwg to gerber
Hi..
someone had sent me a .dwg file.
However, the format that is required by a PCB company is in -- Gerber.
Can someone tell me how to convert .dwg file to gerber file ?
thanx
dwg to gerber converter
I don't know of any program that will convert a .DWG file directly to Gerber. You would have to use one of the many software programs that convert .DWG to .DXF first. You would then have to read the .DXF file into a CAM program such as Gerbtool or CAM350, and output the Gerber file.
If you want, you can PM the file to me. I can try to generate a Gerber for you.
    sumit007
