duration of time between two front C code
MARWEN007
Junior Member level 2
Hey everyone, well I would calculate the time in seconds between my rising input signal is a square wave frequency of 50 Hz and amplitude 5V I found a good sample code in the index of peak I c compile knows not that solve my problem or is nn 't there any constraints or variables to modify the code if you like it give me your idea and your comment and your advice because I want the similer on isis and display whenever the time between the two fronts here's my code as you isis diagram on the board pinout please
#if defined(__PCM__)
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#include <lcd.c>
long rise,fall,pulse_width;
#int_ccp2
void isr()
rise = CCP_1;
fall = CCP_2;
pulse_width = fall - rise; // CCP_1 is the time the pulse went high
} // CCP_2 is the time the pulse went low
// pulse_width/(clock/4) is the time
// In order for this to work the ISR
// overhead must be less than the
// low time. For this program the
// overhead is 45 instructions. The
// low time must then be at least
// 9 us.
void main()
printf("\n\rHigh time (sampled every second):\n\r");
setup_ccp1(CCP_CAPTURE_RE); // Configure CCP1 to capture rise
setup_ccp2(CCP_CAPTURE_FE); // Configure CCP2 to capture fall
setup_timer_1(T1_INTERNAL); // Start timer 1
enable_interrupts(INT_CCP2); // Setup interrupt on falling edge
enable_interrupts(GLOBAL);
while(TRUE) {
delay_ms(10);
printf("\r%lu us ", pulse_width/5 );
To capture the time between two rising edges you only need one CCP (enable interrupts on CCP1):
1) Set the interrupt to occur on each rising edge.
2) On the first rising edge record the CCP_1 value into 'rise' variable.
3) On each subsequent interrupt: calculate the period as CCP_1 - rise; store the current CCP_1 value in 'rise'.
4) Repeat (3) as necessary.
