sharkies
Member level 5
I'm in the process of putting dummy patterns on my chip
Chip includes digital baseband... analog baseband and RF blocks
It's a transmitter basically..
anyways.. I excluded dummy patterns on all analog blocks and RF blocks and including high signal frequency path such as the LO signal that comes from off chip and the 2GHz transmitter output signal that will be going off chip.
Are there other issues that I should consider?
The dummy covers ESD, but I didn't put dummies between the pads fearing that it would cause a lot of parasitic capacitance....
The cautions that I took give tons of density rule error in the DRC. I believe that clearing all DRC may be impractical, but how many violations can be tolerated?
Will TSMC put in dummies manually if the believe it needs more?
