Dual port SRAM using 2 single port SRAM
gold_kiss
Full Member level 4
Full Member level 4
single port ram dual port ram
Hi all,
Anyone has designed Dual Port SRAM using 2 single port SRAM?
Please give references.
Thanks,
Gold_kiss
single-port dual-port sram difference
1. You can use TWO single port RAMs to generate a dual-port RAM: one for even address and another one for odd address.
sram single port
divide the address into 2 parts.
e.g
4 width address.0000 ~ 1111
0000~0111 can be the first ram's address
and 1000~1111 can be the second ram's address.
so. the MSB is the enable signal of each ram.
when 0 , ram 1 is enabled
when 1, ram 2 is enabled
Thanks for your replies.
But what I need is true Dual Port SRAM. In-a-sense read and write to two different ports can happen simultaneously.
Wht explanation you have provided just adds the depth of SRAM kind of address concatination.
Thanks,
Gold_kiss
