Maverickmax
Advanced Member level 1
Dual Diode Module
Hi
I have measured my dual diode with diode check from DMM and the first reading of first diode revealed 0.4V and 0.8V on the second diode. It is clearly the voltage drop between two diodes are different. How can I tell which one of them is good or bad?
MM
I have attached a datasheet for you to understand more.
Hi
MM
