Los Frijoles
Full Member level 1
- Joined
- Oct 5, 2006
- Messages
- 98
- Helped
- 9
- Reputation
- 18
- Reaction score
- 5
- Trophy points
- 1,288
- Location
- Provo, Utah, United States
- Activity points
- 2,252
dot matrix display how
I just finished my hardware designs for a dual color dot matrix display which is controlled by a 8-bit bus. As I was looking at the price to fabricate it (I am using olimex.com), it occurred to me that it would be nice if I distributed this as a kit so that people could have the same thing I came up with without the development cost (I've already spent probably $50-$60 working on this).
Basically the cost breakdown is as follows:
- ~$60-$70 for the PCB and breakout board
- ~$50 for parts
Which gives a total cost of: ~$120
Now the main question is: Assuming this gets off the ground, do you guys think that the average hobbyist would be willing to buy something like this? Being a hobbyist myself I know that $120 is quite a chunk of change for the average shoestring budget. It would come pre-programmed with the microcontroller already on it. Being a kit it would have to be assembled by the buyer rather than myself, so I might was well say right off the bat that the board is almost entirely surface mount with 0.4mm being the finest pitch parts used. I would assemble it myself, but then I would have to factor in labor costs and that would make the cost of the board go up.
The full physical and technical specs:
- 6.3" x 3.05" with two mounting holes on either side of the board .4" from the bottom and .1" from the side.
- Power and control supplied by a 41-pin Hirose DF9 connector. A breakout board would be supplied with the kit since I fit that into the PCB panel.
- Since LED rows are the only things on at the same time it should draw 800mA-1.2A at the most. Worst case scenario (and defying the hardware) it would draw 4A with all the LEDs on.
- Controller is a PIC18F4550 using the PLL to get 12MIPS
- Frame speed is going to be either 30fps or 24fps
- A bootloader of some sort (I still have to write the software) for programming over the 8-bit bus. It would probably hook up to the parallel port on a computer, but not many of those are around anymore.
- Each LED (red & green) will have 4 levels of brighness, so that gives a total of 16 "colors" per pixel.
- Control is done over an 8-bit bus
- All chip components (resistors, capacitors) are size 0805
- Diodes are SOD-123
- IC sizes used are TQFP-44 and TSSOP
1/10th scale demo for seeing how bright it is/isn't: https://www.youtube.com/watch?v=CC-wYQkWSWk
I will have virtual pics of the board as soon as I make the 3d model for the dot matrix modules.
- ~$50 for parts
