cupoftea
I worked with someone whio said Dual cascaded boost should always be done cheaply with no comparator current sense on the 2nd transistor...and just make it an IGBT, in case an overcurrent ever flows through it, it will be more likely to survive it if its an IGBT.......so this was a good way to save money and avoid 2 current sense comparators.
Would you agree its a cheaper way?
Or would you say at 100kHz, tail current issues would dictate against this.?
