[SOLVED] dsPIC30F6014A - Problem with UART Receive, using MPLAB C30 Compiler
miskol
Member level 4
Hi guys,
i have tried programming the dsPIC30F6014A to make the UART1 and UART2 to function properly for days now.
1) i started with using CCS C Compiler, successfully able to send and receive from both UARTs. the problem is however:
- UART calls (e.g getc(), puts()) cannot be placed in a function, it works only in main().
- main problem is however, after calling few puts(), the mC freeze. after removing a single puts(), everything works again.
- suspecting the Compiler itself is buggy, i change my coding to MPLAB C30 Compiler.
2) using C30 Compiler is really hard, having to set manually configuration at low-level programming unlike CCS C Compiler. however i finally able to get the UARTs working, only 1 problem halting my progress:
- not able to check if data is available in receive buffer thus i also cannot check if i can receive from the UARTs with my coding.
- URXDA is always high.
Please help, most importantly on the case of using C30 Compiler. if anyone can share a working dsPIC30F6014A UART code that would be helpful. i have tried many Microchip given examples and they dont work out-of-the-box. my code is based on template given for 30F6014A. as shown is my coding using MPLAB C30 Compiler.
Please help, thank you.
#define FCY 20000000UL
#include <p30f6014A.h>
#include <libpic30.h>
#include <stdio.h>
#include <delay.h>
#include <uart.h>
//Configuration bits
_FWDT(WDT_OFF);
_FOSC(CSW_FSCM_OFF & HS);
_FBORPOR(PBOR_ON & BORV_27 & MCLR_EN);
_FGS(CODE_PROT_OFF);
/* Define constants		                            */
#define LED1 LATCbits.LATC13
#define LED2 LATCbits.LATC14
#define U1TXIF IFS0bits.U1TXIF
#define U1RXIF IFS0bits.U1RXIF
#define U1TXBF U1STAbits.UTXBF
#define U1TRMT U1STAbits.TRMT
#define U1RXDA U1STAbits.URXDA	//The URXDA status bit will be set whenever data is available in the buffer.
#define U2TXIF IFS1bits.U2TXIF
#define U2RXIF IFS1bits.U2RXIF
#define U2TXBF U2STAbits.UTXBF
#define U2TRMT U2STAbits.TRMT
#define U2RXDA U2STAbits.URXDA	//The URXDA status bit will be set whenever data is available in the buffer.
/************* START OF GLOBAL DEFINITIONS **********/
/* Define global variables without attributes */
int variable3;
char Buf[80];
char * Receiveddata = Buf;
/************** END OF GLOBAL DEFINITIONS ***********/
void ConfigIntUART1(unsigned int config);
void ConfigIntUART2(unsigned int config);
void OpenUART1(unsigned int config1,unsigned int config2, unsigned int ubrg);
void OpenUART2(unsigned int config1,unsigned int config2, unsigned int ubrg);
void WriteUART1(unsigned int data);
void WriteUART2(unsigned int data);
char DataRdyUART1(void);
char DataRdyUART2(void);
unsigned int ReadUART1(void);
unsigned int ReadUART2(void);
void mCputc(const char *str, int stream);
unsigned char mCgetc(int stream);
void mCnewLine(int stream);
/************* START OF MAIN FUNCTION ***************/
int main ( void )
	unsigned int baudvalue;
	unsigned int UMODEvalue;
	unsigned int UXSTAvalue;
	unsigned int RX1_data;
	unsigned int RX2_data;
	LATC = 0x0000; //Initialize LED pin data to off state
	TRISC = 0x0000; //Set LED pins (PORTC) as outputs
	LED1 = 0; LED2 = 0;
	U1RXIF = 0; U2RXIF = 0;
	U1RXDA = 0;
	/* Turn off UART1module */
	CloseUART1(); CloseUART2();
	/* Configure uart1 & uart2 receive and transmit interrupt */
	ConfigIntUART1(UART_RX_INT_EN & UART_RX_INT_PR1 & UART_TX_INT_DIS & UART_TX_INT_PR2);
	ConfigIntUART2(UART_RX_INT_EN & UART_RX_INT_PR1 & UART_TX_INT_DIS & UART_TX_INT_PR2);
	/* Configure UART1 module to transmit 8 bit data with one stopbit. */
	baudvalue = 32;
	UMODEvalue = UART_EN & UART_IDLE_CON &
		UART_DIS_WAKE & UART_NO_PAR_8BIT &
		UART_1STOPBIT;
	UXSTAvalue = UART_INT_TX_BUF_EMPTY &
		UART_TX_PIN_NORMAL &
		UART_TX_ENABLE &
		UART_INT_RX_3_4_FUL &
		UART_ADR_DETECT_DIS &
		UART_RX_OVERRUN_CLEAR;
	OpenUART1(UMODEvalue, UXSTAvalue, baudvalue);
	OpenUART2(UMODEvalue, UXSTAvalue, baudvalue);
	while(1)
		LED1 = 1; __delay_ms(10);
		LED1 = 0; __delay_ms(10);
		mCputc("UART1 Send!", 1); __delay_ms(1); mCnewLine(1);
		mCputc("UART2 Send!", 2); __delay_ms(1); mCnewLine(2);
		if(U1RXDA==1) // check if data is ready in UART1
                //** problem is here, the mC always comes in here even though no input to UART1 is given.
			LED2 = 1; __delay_ms(10);
			RX1_data = ReadUART1();
			LED2 = 0; __delay_ms(10);
	if (stream == 1)
		while((*str) != 0)
			while(U1TXIF && U1TXBF);	//Wait for TXREG Buffer to become available and TX Buffer is empty
			U1TXREG = (*str);			//Write data
			str++;						//Next goto char
	if (stream == 2)
		while((*str) != 0)
			while(U2TXIF && U2TXBF);	//Wait for TXREG Buffer to become available and TX Buffer is empty
			U2TXREG = (*str);			//Write data
	char RX_BUF;
	if (stream == 1)
		while(!U1RXIF);	//Wait for a byte
		U1RXIF = 0;
		RX_BUF = U1RXREG;
	if (stream == 2)
		while(!U2RXIF);	//Wait for a byte
		U2RXIF = 0;
		RX_BUF = U1RXREG;
	return (RX_BUF);
	if (stream == 1)
		while(U1TXIF && U1TXBF); WriteUART1(10);
		while(U1TXIF && U1TXBF); WriteUART1(13);
	if (stream == 2)
		while(U2TXIF && U2TXBF); WriteUART2(10);
		while(U2TXIF && U2TXBF); WriteUART2(13);
/****** START OF INTERRUPT SERVICE ROUTINES *********/
/* This is UART1 transmit ISR */
void __attribute__((interrupt, auto_psv)) _U1TXInterrupt(void)
	U1TXIF = 0;
/* This is UART1 receive ISR */
void __attribute__((interrupt, auto_psv)) _U1RXInterrupt(void)
	U1RXIF = 0;
	/* Read the receive buffer till atleast one or more character can be
	read */
	while(DataRdyUART1())
		( *( Receiveddata)++) = ReadUART1();
/* This is UART2 transmit ISR */
void __attribute__((interrupt, auto_psv)) _U2TXInterrupt(void)
	U2TXIF = 0;
void __attribute__((interrupt, auto_psv)) _U2RXInterrupt(void)
	U2RXIF = 0;
	read */
	while(DataRdyUART2())
		( *( Receiveddata)++) = ReadUART2();
/********* END OF INTERRUPT SERVICE ROUTINES ********/
miskol
Member level 4
for updates, i have been able to use both dsPIC30F6014A's UART1 and UART2.
below is the functions that can be used for Transmit, Receive, and Send String:
Examples of use:
for Transmit
// character 'a' will be sent through UART1
mCputc('a', 1);
// character 'a' will be sent through UART2
mCputc('a', 2);
for Receive
char status;
// variable status will receive a character from UART1
status = mCgetc(1);
// variable status will receive a character from UART2
status = mCgetc(2);
for String
// send a string through UART1
mCputs("Initialization Complete...\r\n", 1);
// send a string through UART2
mCputs("Initialization Complete...\r\n", 2);
    * PUBLIC FUNCTION: mCputc
    * PARAMETERS:
    * ~ uc_data        - The data that we want to transmit.
    * ~ stream        - '1' to select UART module for UART1 and '2' for UART2.
    * RETURN:
    * ~ void
    * DESCRIPTIONS:
    * This function will transmit one byte of data using UART1 or UART2. This is a blocking
    * function, if the transmit buffer is full, we will wait until the
    * data in the buffer has been sent out before we move in the new data.
    void mCputc(unsigned char uc_data, int stream)
        switch (stream)
            case 1:
                // Wait until the transmit buffer is ready for new data.
                while (U1STAbits.UTXBF == 1);
                // Transmit the data.
                U1TXREG = uc_data;
                break;
            case 2:
                while (U2STAbits.UTXBF == 1);
                U2TXREG = uc_data;
                break;
    * PUBLIC FUNCTION: mCgetc
    * PARAMETERS:
    * RETURN:
    * ~ The data received from the UART1 or UART2.
    * DESCRIPTIONS:
    * This function will receive one byte of data using UART1 or UART2. This is a blocking
    * function because if the receive buffer is empty, we will wait until the
    * data is received.
        unsigned char receive;
        switch (stream)
            case 1:
                // Wait until there is data available in the receive buffer.
                while (U1STAbits.URXDA == 0);
                // Clear the overflow bit and return the received data.
                U1STAbits.OERR = 0;
                receive = U1RXREG;
                break;
            case 2:
                while (U2STAbits.URXDA == 0);
                U2STAbits.OERR = 0;
                receive = U2RXREG;
                break;
        return receive;
    * PUBLIC FUNCTION: mCputs
    * PARAMETERS:
    * ~ csz_string    - The null terminated string to transmit.
    * RETURN:
    * ~ void
    * DESCRIPTIONS:
    * Transmit a string using UART1 and UART2.
    void mCputs(const char* csz_string, int stream)
        switch (stream)
            case 1:
                // Loop until the end of string.
                while (*csz_string != '\0')
                    uart1_transmit(*csz_string);    //Write data
                    csz_string++;                    // Point to next character.
                break;
            case 2:
                    uart2_transmit(*csz_string);    //Write data
                break;
