DS18B20 Pic Assembler Code
wp100
Advanced Member level 6
Prime Meridian
Had previously tried and failed to code the DS18B20 in Pic Assembler.
It seems such a complicated routine for such a simple function.
Have searched the web for code examples but have yet to find any that actually work.
Just hoped if someone out there has a working Pic Assembler program they would be good enough to let me have a copy of .
Thanks.
Hi Fidelis,
Many thanks for that link, had spent hours searching but never saw that site.
Your link to the site works ok and I downloaded the files which build fine and actaully run in the Simulator so feel confident it will work well when the sensors actually arrive.
Thanks again !
I have coded in Pic assembler in the past .But the only reason is because i was implementing a peripheral .I needed to have perfect timings to interface the pic with a real time system. It took me a month of hard work .I ended up with a 12 pages long perfect working code .If you are don't need that type of precision or the Pic you are using has enough processing power to deal with the design .Use C code .Don't waste your time .Learning something so tedious .That once you do it one time you will never do it again .!
