toruk.makto
Newbie level 1
i want drive a ds1307 with ATmega32 in assembly
(ATmega32 works in 8 MHZ internal oscillator mode)
i use this simple program for drive ds1307 and its not working ...
leds randomly turn on and off
the purpose of this program is first send primary Values to ds1307
(second/minute/hour/day/month/year)
and then reading second and send it to porta.(to show on leds)
would you please correct this program or write another simple program like this one
(i am beginner in assembly and i searched internet and found nothing )
attention: this mode i used in my program called hardware i2c mode which is used pc0 and pc1 as scl and sda.
the program:
schematic:
the program:
Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 /* * ds1307.asm * * Created: 1/17/2014 5:13:16 PM * Author: Home */ .include "m32def.inc" .org 00 ;---------------------------Initialized stack pointer ldi r16,high(ramend) out sph,r16 ldi r16,low(ramend) out spl,r16 ;----------------------make porta output ldi r16,0xff out ddra,r16 ;--------------------------start i2c connection and put zero in 07H of ds1307 (primary setting) call i2c_init call i2c_start ldi r16,208 call i2c_send ldi r16,0x07 call i2c_send ldi r16,0x00 call i2c_send call i2c_stop ;----------------- send primary values to set (hour/minute/second) in ds1307 call delay call i2c_start ldi r16,208 call i2c_send ldi r16,0x00 call i2c_send ldi r16,0x55 call i2c_send ldi r16,0x58 call i2c_send ldi r16,0b00010110 call i2c_send call i2cstop ;-------------------reading second from ds1307 and send to porta call delay main: call i2c_init call i2c_start ldi r16,208 call i2c_send call i2c_start ldi r16,209 call i2c_send ldi r16,0x00 call i2c_send in r18,twdr out porta,r18 call i2c_stop call delay_1sec rjmp main ;-----------------------------------Subprograms delay_1sec: ldi r19,250 l3: ldi r20,200 l2: ldi r21,40 l1: nop dec r21 brne l1 dec r20 brne l2 dec r19 brne l3 ret delay: ldi r17,0xff a1: dec r17 nop brne a1 ret i2c_init: ldi r16,1 out twsr,r16 ldi r16,123 out twbr,r16 ldi r16,(1<<twen) out twcr,r16 ret i2c_start: ldi r16,(1<<twint)|(1<<twsta)|(1<<twen) out twcr,r16 wait1: in r16,twcr sbrs r16,twint rjmp wait1 ret i2c_send: out twdr,r16 ldi r16,(1<<twen)|(1<<twint) out twcr,r16 q1: in r16,twcr sbrs r16,twint rjmp q1 ret i2c_stop: ldi r16,(1<<twint)|(1<<twsto)|(1<<twen) out twcr,r16 ret
schematic:
