Is there any possibility to drive transistor as switch by using audio signal from line out ? Efficient & simple will work like a charm.
Iv already created Signal what is pulsed DC...
So far as i know to use transistor as switch theres nothing complicated coz voltage and current should do the "trick"
Do i need to ground something down ?
What about a connecting line out to base, will it work just to connect base line out "positive something" with base.
Although can i exceed 20000 Hz limit ? Signal will be really simple... On what depends tease limitations ? Is the sound card driving (control) part behind it or ???
Can i clock sound card somewhere from bios or something ?
Im not sure what u wanna do with line out...But if u wanna exceed the 20KHz limit, the sound cards are built to generate audible frequecies (20-20KHz). I dont think sound cards are designed to generate ultrasonic signals (>20KHz)...And if u simply wanna drive a transistor with line out u can do that...Choose a transistor with High hFE ratings...and connect the base of transistor to line out...
The only advantage of a PC sound card line out is the ability of playing *.wav files without writing a line of code. Apart from that, any digital interface, e. . printer port, RS232 would be better suited to drive a switch transistor.
