hi,
The IRLML6402 is a P MOSFET, check the voltage polarities
E
Doesn't the voltmeter show 9V at the drain?
Never let the gate floating.then after when i keep the gate pin floating
B2 has two connections, you only show one.i have a connected a LED to B2
A Led has two connections. How you connected it is unclear.
--> show the complete schematic wher we can see your ON setup and OFF setup.
Klaus
Really? You have connected the gate to ground, Vgs = -9V, MOSFET permanently on.Complete circuit diagram attached.
If you want to further modify the schematic, please notice that Vgs has to be applied between gate and source. Source node is at input voltyage level (+9 V). To switch the MOSFET off, you'll apply Vgs < 0.5V respectively > 8.5 V relative to ground, to turn it on, Vgs > 2.5 V, respectively < 6.5 V relative to ground.
A 5V source referred to ground (e.g. a microcontroller IO pin) won't be able to switch the MOSFET off without a level shifter.
why the voltage does not drops below 5v when gate is connected to (+).
