Jun 16, 2006 #1 J Jing Junior Member level 1 Joined Jan 27, 2004 Messages 19 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 171 I use dracula to do DRC. After I execute jxrun.com, I got " Cound not check out DRAC2CORE (2) 1.000000". how to solve this problem? thanks so much
Jun 21, 2006 #2 A armity Newbie level 6 Joined Apr 23, 2004 Messages 11 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 63 Re: Dracula DRC failed check your DRC rule file!
Jun 21, 2006 #3 J Jing Junior Member level 1 Joined Jan 27, 2004 Messages 19 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 171 Dracula DRC failed in the dracula drc rule file, i only need to setup indisk, outdisk, primary and printfile what else i need to change
Jun 23, 2006 #4 R road_0506 Member level 4 Joined Jun 23, 2006 Messages 69 Helped 7 Reputation 14 Reaction score 0 Trophy points 1,286 Location Phils Activity points 1,628 Re: Dracula DRC failed check the location of your streamfile... or the filename of your top layout. is it the same with the one you inputted?
Sep 10, 2006 #5 L laydesign Newbie level 3 Joined Sep 10, 2006 Messages 4 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,297 Re: Dracula DRC failed road_0506 said: check the location of your streamfile... or the filename of your top layout. is it the same with the one you inputted? Click to expand... PDRACULA LICENSE have not been active.
Jun 11, 2007 #6 K krrao Junior Member level 2 Joined Feb 13, 2006 Messages 24 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,517 Re: Dracula DRC failed Hi , The license for Dracula is not checked out. Make sure that license is free and then give the run.
