tj1961
Newbie level 1
I need to a board that can handle the following. Can anyone help, please?
1st timer is set to 5 seconds. This timer is dependant upon 2nd timer, as the 5 seconds only applies immediately after the 2 hour timer below has applied power. It needs to connect to a relay to drive a small motor for the 5 seconds.
2nd timer is set to 2 hours and needs to power the motor as well
An LDR needs to be incorporated so that both timers are off during hours of darkness.
Any help would be appreciated.
Thank you.
TJ
Thank you.
TJ
