Dear Forum Members,
Nowadays I Am Working On Signboard Project, In This Project I Have To place the components on both sides of the board.any tips or suggestions of how to accomplish this on ORCARD LAYOUT.NOTE that the components are to be placed on both side's of the board i,e Top And Bottom Side's
I usually try to avoid placing anything but small decoupling caps on the bottom side when doing 2-sided layout since this will provide a nice ground plane on the bottom if there are minimal traces on hte layer.
Re: Double Side PCB, Top And Bottom Side's Components Placem
when i draw a two side pcb board , i placed decoupling con on bottom side if you have big pcb design there are a lot of decoupling con i think you place decoıupling con on bottom side
Press T button key on the keyboard when you want to place the component on the bottom side. T is for toggling the components between top and bottom side, in ORCAD LAYOUT.
