Does VHDL does not support different size ports connection(for output)
syedshan
Advanced Member level 1
Jeonju, South Korea
Dear all,
My inner module's output port is 14 bit and outer module's output port is 64 bits.
Hence I connect
In_mod => out_mod(13 downto 0);
while
out_mod(63 downto 14) <= (others => '0');
But what I am receiving is all ports connected to ground. I am checking this using RTL viewer in ISE
Does VHDL does not support this thing.
I have tried similar thing in verilog and it works perfect.
Please note that for input port similar case works fine in VHDL
Bests,
Shan
TrickyDicky
Advanced Member level 5
can you post the whole code - your code is not very clear.
syedshan
Jeonju, South Korea
Thank you for reply.
I will send you the ports connection part I think. I have just posted the relevant part for your convenience.
Hope this will help.
entity main_blk is
port(
out_0_out_data : out std_logic_vector( 63 downto 0);
end entity;
architecture behave of main_blk is
component Mean_subt is
generic(
Din_width 	: 	integer	:= 14;
Dout_width	: 	integer	:= 14
port (
clk, rst			: in 	std_logic;
EN				: in 	std_logic;
ext_trigger		: in	std_logic;
in_adc			: in 	std_logic_vector(Din_width-1 downto 0);
actual_out		: out std_logic_vector(Dout_width-1 downto 0);
valid_out 		: out std_logic
end component;
begin
inst1_mean : Mean_subt
generic map (
Din_width 	=> 14,
Dout_width	=>	14)
port map(
actual_out		=>	out_0_out_data((13 downto 0),
out_0_out_data(63 downto 14) => (others => '0');
end architecture behave;
Bests,
Shan
TrickyDicky
There are a couple of issues with the posted code:
actual_out from inst1_mean is 64 bits wide, and you're trying to connect it to a 14 bit bus.
then out_0_out_data has all bits connected to '0', so you would get multiple driver errors (ie. it wont even compile) on out_0_out_data.
So I dont think you posted the code correctly.
syedshan
Jeonju, South Korea
I am really sorry for that.
I have edited the code in my previous message as you mentioned. Now it is as in my actual code
Thank you,
Shan
TrickyDicky
There is no problem with the code. I suspect the problem is elsewhere.
