Does Monte carlo variation depends on input common mode of amplifier?
pmr9
Junior Member level 2
Hi All,
I have a question regarding MC variation (offset of amplifier), Does Monte carlo variation depends on input common mode of amplifier??
Thanks
Thanks crutschow, Just thinking that reduced common mode will reduce gm, that increases the mismatch contribution from the load devices. Considering the relation: (gm_diff/gm_load)*Vth_mismatch_loads
When common mode position drives the front end into a
linear region (MOS) or saturation or near-cutoff (BJT)
the gain will be reduced. The common mode position at
which this rolls on, is process / temp / voltage variable.
So at extreme common mode positions you may see
"enhanced" process sensitivity (like, if you're 0.5V from
the lower rail with a NMOS front end, and VTN varies
0.3 - 0.7V, half of the distribution might be into cutoff
of the diff pair tail current and gain tanks, bandwidth
pulls in, etc.).
This is why rail-rail input stages are interesting.
