Does GDS supports text ?
truebs
Full Member level 5
Asia
Hi friends,
While making layouts we usuallt text various nets and ports, and devices.
Is this info contained in GDS too, if I write a a GDS out of my layout ?
or this is only for user's reference at Layout and verification tool stage ???/
If no, Is there any way to put text in GDS ???
Thanks :D
yes gds support text..........label layers are for this purpose only.
you have label layers the same you used in layout......if you know the layer number , that you can select that layer and you will be able to see the layer name.
so just do 1 thing . select only the layer number of the label layer that you might have used in the layout.
hope this answers........your question.
very well said stuck.
