Does fm transceiver come in single chip, where to buy it ??
nipun
Member level 2
Member level 2
mc13175
do fm transceiver come in a single chip.if yes where can i purchase it.
fm transceiver
ADF4360-8 from analog device is an almost complete FM transmitter PLL system. You need to add only the audio part.
Re: fm transceiver
Re: fm transceiver
You don't state the application or band of interest but I assume it is not cell phone.
For 49 mhz operation try the Atmel U3600BM. This is widely available and actually will cover 30-70 Mhz.
If you have access to a Himark distributor you could try the Himark TR5100 if it is still available. This will cover from 30-150 MHz or so.
In both cases you just need a few periferal components for a complete FM xceiver. Hope this helps.
Re: fm transceiver
Philips Semicondutor has FM transceiver chip.
Re: fm transceiver
Take a look on the Chipcon website.
Bye
