Does Chipcon's CC2430 for ZigBee do automatic routing?
Sadegh.j
Advanced Member level 3
Does Chipcon's CC2430 for ZigBee do automatic routing or should I write a program my self.
cc2430 examples
The TI ZSTACK implement a full ZigBee compliant software on the CC2430. Then routing is done automatically as ZigBee spec do.
cc2430 software examples
This means that I should send what ever to where ever and just leave it and it will send it there?
have you tried it your self? I have tried a code which takes care of sending data to all the nodes. No routing is included.
Thanks
cc2430 sample code
Yes
Yes, but not completely for now.
Routing is done by the mesh. Also, you can have in return an acknowlegment of the good data transmission.
    Sadegh.j
7.50 cc2430
COOL, thanks
iar embedded workbench cc2430
Dear Sadegh.j,
What version of IAR, do you used?
What version of Z-Stack, do you used?
I have download IAR "IAR Embedded Workbench for 8051 v. 7.50A Eval"
and "swrc073d - Full ZStack-CC2430-1.4.3-1.2.1.zip"
I tried to compile the examples program provided by TI successfully,
but when I burn to the CC2430EB it is do not work correctly.
one and the only one sample thar work correctly is
"swrc019e - CC2430 Software Examples(BasicRF).zip"
could you give me segestion, why the examples do not work almost at all.
is this problem cause the version of IAR ? since ZStack sample writen
with IAR v7.30??
best regards
Siswanto
