Does anyone ever buffer instrumentation amps?
q2418130103p
Newbie level 6
Newbie level 6
Instrumentation amps with low bias (pA) usually have higher noise (>10nV/rHz).
Does anyone ever buffer a low noise (<10nV/rHz) instrumentation amp, which probably has nA bias, with low noise low bias op amps?
Are there any other ways to mitigate the noise contribution of low bias instrumentation amps?
Thanks
You find low noise FET OPs down to about 3 nV/√Hz noise density. Using it in a differential input stage with gain will result in about 4.5 nV/√Hz input referred noise. Lower noise at the cost of higher offset voltages and drift can be achieved with discrete JFET input stages.
I am not sure I know what you mean by 'discrete jfet input stages'. Could you elaborate, or provide a reference?
Discrete means using individual JFET transistors instead of IC. I just wanted to mention the option, not suggest a complete design solution.
