Documents which explain poles and zeros in control systems/analog circuits
sridhara
Member level 4
Member level 4
where can i get a good material about poles and zeros....explanation in terms control systems and also in analog circuits.......
poles and zeros
Circuit Analysis
By
William Hyat
physical meaning of poles and zeros
for stable systems,pole should be in right hand of S plane (negative real value)and if it is imaginary axis(non real) ,it indicates system is oscillatory...
if it is real and imaginary( a complex),then system response is damped oscillation.....
if poles are left in Splane then system is highly unstable...
physical significance of poles and zeros
modern control system
dorf
control system
ogata
and me if u have some questions.
modern control systems dorf rapidshare
Concept is very simple.
When you see a pole, the output from the transfer function give you a infinite value..
WHen you see a zero, the output is 0.
hi
also I say you to see the books by:
1) Hayt
2) Dorf
3) Nelson
network analysis van valkenburg rapidshare
i want to know about the effect of addition of pole or a zero to a circuit....
physical significance fo poles and zeros
pole zero cancellation method can be used for cancellation techinque.........
explanation about poles and zeros
sedra and smith.
network analysis van valkenburg + rapidshare
sedra&smith is always a good book and you can find the definitions of poles and zeros and their realtion of the stability and the gain af any system in the book
hi,
u can read the book "Network Analysis" by Van Valkenburg.
A very good introduction to poles and zeros is given in that book
nyquist stability criterion
try this book **broken link removed**
van valkenburg network analysis rapidshare
sorry i 4got the psw: deadzoners.info
stability poles and zeros
can anyone tell me what is the physical meaning of adding a pole and zero.I want to ask what we do in reality when we say
we added a pole to the system(what change or component ve we introduced in our construction)
we added a zero to the system
Added after 20 minutes:
addition of pole makes system less stable but decreases its steady state error .
adding a zero makes the system stable but its steady state error is increased.
poles and zeros in circuits
see ogata's control system book of kou's book
meaning of pole in circuits
Can anyone tell me what is the physical meaning of adding a pole and zero.I want to ask what we do in reality when we say we added a pole to the system(what change or component ve we introduced in our construction) we added a zero to the system ...
A question repeated on behalf of our friend umairmahmood and also may persons like us..
Santom
van valkenburg network analysis rapidshare.com
Santom
OK - here is a short explanation:
1.) Adding a pole means to have an additional factor (1+sT) in the denominator of a transfer function. This can be done by using an additional lowpass of 1st order.
2.) If (1+sT) appears as an additional factor in the nominator it acts like a zero.
This can be accomplished - for example - by adding another R in series with the cap of the low pass circuit.
Added after 18 minutes:
That´s definitely not true.
Have you ever heard about lag compensation - a method for stabilizing a circuit by adding a pole.
