T
treez
Do vias have solder mask over them?
That's the same thing I addressed with "reduced soldermask opening". It e.g. allows a via to touch a same net pad and still have sufficient soldermask feature between pad and via opening.I typically leave a slightly negative solder mask expansion so they can be used as test points. See attached image:
