Do Interrupt and LCD at the same time
metals
Junior Member level 2
Hi!
The problem is..
I want this program to flash the LEDs on Port C. At the break from RB0 (falling edge) I want to write "Interrupt" on the LCD display and display it for a couple of seconds. I shall use the opportunity to have a pull-up resistors on Port B inputs.
I have this code down here but the only thing that is working is the LED lights :cry:
Can anyone see what I'm doing wrong?
List P=16F877 ;Processorangivelse
status			equ			0x03
RP0				equ			0x05
intcon			equ			0x0b
RB0flag			equ			0x01
opt_reg			equ			0x81
portB			        equ			0x06
portC			        equ			0x07
trisB			        equ			0x86
trisC			        equ			0x87
trisD			        equ			0x88
var1			        equ			0x20
var2			        equ			0x21
w_temp			equ			0x22
status_temp		equ			0x23
var3			        equ			0x24
portD			        equ			0x08
ASCII			equ			0x25
tab_pek			equ			0x26
ganger			equ			0x27
En				equ			0x01
Z				equ			0x02
PCL				equ			0x02
Var_1			equ			0x28
Var_2			equ			0x29
				org			0x00
				clrf		        status
				movlw		0x00
				movwf		0x0A
				goto		        init
;***********interrupt vector******************
				org			0x04
				goto		       interrupt
;************subroutines*****************
wait			        movlw		0xff
				movwf		var2
loop_2			movlw		0xff
				movwf		var1
loop_1			decfsz		var1,1
				goto		        loop_1
				decfsz		var2,1
				goto		        loop_2
				return
;*******interrupt subroutin**********************
interrupt			movwf		w_temp
				swapf		status,0
				movwf		status_temp
				movlw		0x50
				movwf		var3
loop_3			call		        wait
				decfsz	 	var3,1
				goto		        loop_3
				bcf			intcon,RB0flag
				swapf		status_temp,0
				movwf		status
				swapf		w_temp,1
				swapf		w_temp,0
				retfie
waitms			movlw		0x0A
				movwf		Var_2
loop2			        movlw		0x64
				movwf		Var_1
loop1			        decfsz		Var_1,1
				goto		        loop1
				decfsz		Var_2,1
				goto		        loop2
				return
init			        clrw
				movwf		portD
				movwf		portB
				bsf			status,RP0
				movwf		trisD
				movlw		0xff
				movwf		trisB
				bcf			opt_reg,7
				bcf			opt_reg,6
				bcf			status,RP0
				bsf			intcon,4
				bsf			intcon,7
				clrw
				movwf		portD
				bsf			status,RP0
				movwf		trisD
				bcf			status,RP0
				call		        LCDinit
enable			bsf			portD,En
				call		        wait
				bcf			portD,En
				call		        wait
				return
main			        clrf		        tab_pek
				movlw		0xAA
				movwf		portC
				call 		        wait
				call 		        wait
				movlw		0x55
				movwf 		portC
				call 		        wait
				call 		        wait
				goto 		        main
again		                movfw		tab_pek
				call		        text
				iorlw		        0x00
				btfsc		       status,Z
				goto		       klar
				call		       show_lcd
				incf		       tab_pek,f
		                goto		       again
klar		               	goto		        klar
text			        addwf		PCL,f
				retlw		'I'
				retlw		'n'
				retlw		't'
				retlw		'e'
				retlw		'r'
				retlw		'r'
				retlw		'u'
				retlw		'p'
				retlw		't'
show_lcd		        movwf		ASCII
				andlw		0xf0
				movwf		portD
				bsf			portD,0
				call		        enable
				swapf		ASCII,w
				andlw		0xf0
				movwf		portD
				incf		        portD,f
				call		        enable
				return
				movlw		0x00
				movwf		portC
				call		        wait
				movlw		0xff
				movwf		portC
				call		        wait
				goto		        main
LCDinit			movlw		0xff
				movwf		ganger
loop3			        call		        waitms
				decfsz		ganger,1
				goto		        loop3
				movlw		0x30
				movwf		portD
				call 		        enable
				movlw		0x05
				movwf		ganger
loop4			        call		        waitms
				decfsz		ganger,1
				goto		        loop4
				movlw		0x30
				movwf		portD
				call		       enable
				call		        wait
				movlw		0x30
				movwf		portD
				call		        enable
				call		        waitms
				movlw		0x20
				movwf		portD
				call		        enable
				call		        waitms
				movlw		0x20
				movwf		portD
				call		        enable
				movlw		0x80
				movwf		portD
				call		        enable
				call		        waitms
				movlw		0x00
				movwf		portD
				call		        enable
				movlw		0x10
				movwf		portD
				call		        enable
				call		        waitms
				movlw		0x00
				movwf		portD
				call		        enable
				movlw		0x60
				movwf		portD
				call		        enable
				call		        waitms
				movlw		0x00
				movwf		portD
				call		        enable
				movlw		0xe0
				movwf		portD
				call		        enable
				call		        waitms
				return
;************************lcd_clear**********************
lcd_clear		        movlw 		 0x00
				movwf		portD
				call 		        LCD_Enable
				movlw		0x10
				movwf 		portD
				call		        LCD_Enable
				return
;************************LCD_Enable*************************
LCD_Enable 		bsf 		portD,En
				call 		loop1
				bcf 		portD,En
				call		loop1
				return
				end
Hi!
Well a good try, but you have quite a few errors to sort out.
What you are looking to do is a staight forward task but its perhaps a lot all together if its your first attempt; have you tested simpler routines like a led flasher before ?
I have not run your code, though it does build ok, but here are some areas you need to look at.
You have specified many of the System Registers such as Ports and PCL etc.
No need to do that if you use this code after your LIST statement.
#include <p16F877.inc>
You still need to specify your User registers
After Org 0x000 you use several instructions before the Interrupt Vector 0x004, if you add anymore instructions at that point it will overflow into the ISR routine at 0x004 - much better to just use GOTO INIT after 0x000
On the 16F877 the Interrupt need to have whats called Context Saving - you need to see the datasheets for the examples of how to do that - without it the ISR will not work.
Have you written the lcd routine yourself ? - does it work ? - its a complex bit of programming. Also have you checked the Waits / Delays give the correct timings ?
Check those points out and then give it another try - are you using hardware or Simutlators ?
