T
treez
Hello,
We need a single channel DAC chip , between 8 to 12 bits.
We found the MCP4706, however, it has EEPROM.
We do not need EEPROM and so do not want it, as EEPROM dies after so many read/writes and that will then render the MCP4706 “dead”.
We want it to last and not die on us.
Do you know of a similar chip to MCP4706 that doesn’t have EEPROM?….they all seem to have it.
We only need to write to the DAC once every hour or so.
We wish to load values by bit-bashing the I2C protocol..is this OK?….we do not know how to use the I2C module inside our PIC18F65K22 microcontroller.
MCP4706 DAC datasheet
https://ww1.microchip.com/downloads/en/DeviceDoc/22272C.pdf
