neazoi
Advanced Member level 6
- Joined
- Jan 5, 2008
- Messages
- 4,157
- Helped
- 13
- Reputation
- 26
- Reaction score
- 15
- Trophy points
- 1,318
- Location
- Greece
- Activity points
- 37,198
Hello, I consider making a small cheap (~ $100) spectrum analyzer for 0-200MHz with -75dB sensitivity. This is a standard superhet design using an opamp sweeper, mini circuits LO, mixer and a helical filter, followed by a chip to perform the rest of the functions. There will be two switched resolution bandwidth filters, one using ceramic filters (wideband) and one using crystal filters (narrowband). I believe this should give enough resolution at slow sweep rates, to monitor the transients of an ssb signal.
Note that it is intended for the radio amateur, not the proffessional.
I already own a 500MHz SA (FFT function of my scope), but the analogue SA seems very straight forward. Just to mention that my Tektronix 491 is not capable of below 10MHz, which is not good for radio amateur purposes.
Looking at ebay, for prices comparison, I could not find a 200MHz or so SA and some similar products use FFT (as expected) and whereas they combine a scope with the SA, they cost more. On the other side these TV tuner based SAs are useless since they begin from 40MHz and up.
You may have more experience in this topic so I would like to ask if such a project is worth to build nowadays if it can be done at ~ $100.
It seems that the SA, even the simpler ones, is still an expensive instrument, despite the advance in technology. So it is worth it to build a simple one?
